Author Topic: IT' fixed i think----- sorry for all the posts but please read this one  (Read 2621 times)
Offline rageraver
how cud i tell if its running lean..... how come he say it sounds hi but you say sounds right lol.... whats psi can the engines take, just dont wanna break anything.
also how cud i turn it down a little then?
just really dont want it to go band.... will the dv lower it a bit or atleast the spike
Offline cullygti
how does it sound right he dont know if or what map is on it a standard engine runs 7psi stage1 boost to18-19psi and holds at 14-15psi if its holding higher than this without a map then summat aint right
Offline JimBR
My k03s with a stage one map used to peak at 19-20psi and hold 17-18. It just depends on the turbo and who mapped it ect
Offline rio_gti
actuator wound too far take it back a touch??
Offline cullygti
thats my point he dont know if its had a map or not
i been sniffing to much of the gloss today if its boosting that high it must be mapped surely  :embarassed:
« Last Edit: 12 June 2012, 22:15 by cullygti »
Offline JimBR
Without a map its definitely too high? But nobody would fit a k04 and not get it mapped surely?  :undecided:
Offline rageraver
why wud it boost that hi inless it was mapped... it sounds fine. also wind the atuator? how do you do that... i didnt wind it in or out, just adjusted the nuts to hold the wastegate arm
Offline rageraver
will that psi naf it up then, just wish  i new if it had a map.... all the reciptes but none for a map....i wud of fort they did tho
Offline cullygti
didnt know it had ko4 cant be arsed to look through old threads  :laugh: but makes sense  :grin:
Offline rageraver
is it possible to boost that high and not hit fuel cut inless it had been mapped?? yh k04 interooler exhaust induction kit
