Author Topic: MK4 Indicators/wipers fault  (Read 5651 times)
Offline Tezmax
« on: 12 June 2012, 17:22 »
Hey, here's a fault ive never come across. Indicators work for about 5mins then stop working. A few days later same happens to my wipers front and rear. (Hazzards work ok). So i park up up for 5mins engine off. Then set off again with all working only for them both to fail 5mins down the road? They do come back during my journey but not for long. Any answers while i go and check for a loose Relay!!  :sad:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline EsSeX dAn
Re: MK4 Indicators/wipers fault
« Reply #1 on: 12 June 2012, 22:20 »
freaky shizz mate. try unplugging em nd replugging them in. is it weather dependant or is it random?
i think i love you.....
Offline Tezmax
« Reply #2 on: 13 June 2012, 19:31 »
Random at start now just dont work. On way to work today realised interior heater blower doesn't work either! Found a thread yesturday with same symptoms, wipers/heater blower and indicators stopped working but replies just dried up with "try fuses" and "maybe relay fault".  :cry:
Offline richw911
« Reply #3 on: 13 June 2012, 21:16 »
Checked the fuse box on top of the battery?
Offline Tezmax
« Reply #4 on: 18 June 2012, 15:14 »
All three fuses on battery ok. All fuses in interior side panel ok. x2 15amp fuses above Relay panel ok (stick ur head right in there and u'l spot em. So just changed the Ignition Switch and hey presto........dont work :shocked: So guys in the chit ere, no indicators, wipers frnt/rear, wiper washers and hot/cold air fan :cry: Any more idea's as im getting withdrawal symtoms from traffic light grand prix's. (not my quote but liked it alot)
Offline Tezmax
« Reply #5 on: 18 June 2012, 18:38 »
Done a bit more fiddling, now i have an airbag fault. :angry:
Offline EsSeX dAn
« Reply #6 on: 18 June 2012, 23:48 »
its definatly something electrical. the air bag fault will be where unplugged fuses for the dash cluster. youll want vag com to clear it. its too much of a concidence to be a plug or relay i think but i might be wrong. its happened before. where are you based? only as i have a indicator switch stalk u cud borrow to see how it goes. that would at least rule one thing out.hope u get it sorted
Offline Tezmax
« Reply #7 on: 19 June 2012, 12:59 »
Tkx for ur support dan, i think im gona try attacking 1 fault at a time like u suggest but i got a bad feeling im not gona get anywhere. Bite the bullet time and take it to stealers :sad:
Offline Tezmax
« Reply #8 on: 05 July 2012, 20:01 »
sry people forgot to close this one out :angry: for those who read this thread the cure was replacing relay 100. by replacing this the indicators, front and rear wipers and interior hot/cold blower all worked after.
As for the air bag fault, vag com sorted 2min job.
much tkx all.
