Author Topic: rubber blanking groumet  (Read 1225 times)
Offline Ray_Ray280
« on: 12 June 2012, 15:33 »
Hello,
I want to de wiper the rear of my golf does anyone know the size of the hole?
thanks
Ray
Offline Dalo Harkin
Re: rubber blanking groumet
« Reply #1 on: 12 June 2012, 15:40 »
I'm interested in this too if someone knows   :smiley:
also what sealant is best to use behind it
« Reply #2 on: 12 June 2012, 15:53 »
24mm grommet (you can get a mixed packet in halfords really cheap) and no sealant needed.
Offline Dalo Harkin
« Reply #3 on: 12 June 2012, 16:03 »
No sealant = some pleb pulling it off  :grin:
Offline Dalo Harkin
« Reply #5 on: 12 June 2012, 17:02 »
Looks smart, may have to purchase one  :smiley:
Offline Ray_Ray280
« Reply #6 on: 12 June 2012, 17:28 »
i brought some groumets from halfords for £1.59 now does anyone know how to remove the rear wiper??
Offline dom
  • Back in a Mk4
« Reply #7 on: 12 June 2012, 17:35 »
Pop the washer cover off, undo the nut and the wiper arm will come off with a little wiggling.
Open the boot, undo the 2 screws inside the grab handles on the inside of the boot. You'll be able to pull the entire black plastic cover off the inner boot lid.
Disconnect the plug for the wiper mechanism and the washer pipe, then it's 3 screws to remove the entire mechanism which will then pull out from the inside. Make sure you block the washer pipe with something :wink:
Offline Ray_Ray280
« Reply #8 on: 12 June 2012, 17:45 »
awesome cheers Dom gives me something to do tomorrow
« Reply #9 on: 12 June 2012, 21:56 »
I would also recommend pulling the pipe off the bottle under the bonnet as well.
