Author Topic: best rear offset for 9" wheels  (Read 3060 times)
Offline stainesy
« on: 11 June 2012, 21:51 »
just been looking at diferant wheels and found some nice wheels i like but they come 7.5j front and 9j rear. i no i can do the fronts at ET20 to have them sit nice but what offset on the rear do i have to make them sit the best with rolled arches
Offline tshirt2k
  • Been there...Done that...
Re: best rear offset for 9" wheels
« Reply #1 on: 12 June 2012, 06:03 »
9's are usually ET15
Mk3 ABF 16VT Megasquirt V3
Offline stainesy
« Reply #2 on: 12 June 2012, 07:33 »
sweet cheers mate
Offline tweed
« Reply #3 on: 12 June 2012, 10:07 »
My sig pic is 9" et15
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #4 on: 12 June 2012, 17:35 »
do you run spacers aswell or is that them sat on the hub ? cheers
Offline tweed
« Reply #5 on: 12 June 2012, 17:40 »
The wheels are et20 but I have a 5mm spacer each side making them et15. And I've got camber shims in set to 20/20 that's -2
Offline tshirt2k
« Reply #6 on: 12 June 2012, 20:26 »
Do the insides of the wheels touch suspension at ET20?
Offline stainesy
« Reply #7 on: 12 June 2012, 22:01 »
Would I need shims aswell then?
Offline tweed
« Reply #8 on: 12 June 2012, 23:00 »
No got about 1" the standard gti wheels sit in more than 9" et20  :wink:
Stainesy it's up to you. I had to pull my arch too. I wanted them flush. If you want poke then don't fit shims and just roll ya arch.
I've tucked my 8" et20 front. That was a mission lol when I first put the front on, they poked out about 30mm  :grin:
Offline stainesy
« Reply #9 on: 13 June 2012, 10:14 »
ok cool well the fronts will be 16" ET20 and only 7.5j so they should be ok with just rolling the arch. so just rolling the rear arch with 16" ET15 and 9j will be ok then? sweet. just need to save up the funds for the wheels now.  :grin:
this is gona look sick. im on a mission now to get these wheels.
