Author Topic: anniversary wheels offset question  (Read 2672 times)
Offline stainesy
« on: 11 June 2012, 14:41 »
as some of you no my mate james has bought a nice mk3 anni. what i want to no is do anni wheels have a diferant offset front and rear?
i ask this as his rear wheels seem to sit very far inside the arches and the front wheels sit pretty flush with the arches.
when i fitted my brand new lensos to my black golf i got them made with an offset of ET20 on all 4 wheels. and the fronts sat flush like his front wheels do and the rears needed a 15mm spacer to make them flush.
so i was thinking maybe his wheels sit like that do to the annis having a lower offset on the rear to make them all sit the same in the arches but maybe he has the fronts on the rear and the rear on the fronts. i can not see any spacers.
i no its probly a silly question and they are probly all the same offset but just seems odd to me that his fronts sit flush and the rears are very far in the arches.
« Last Edit: 11 June 2012, 14:48 by stainesy »
Re: anniversary wheels offset question
« Reply #1 on: 11 June 2012, 14:46 »
Mk3 wheels are a different width to the mk4 version, so I wonder if has a mismatched set.
Offline stainesy
« Reply #2 on: 11 June 2012, 14:50 »
i dont no mate. i dont really no much about the annis. all i no is he has an anni that looks as though its all original but his rear wheels sit right inside the arches
« Reply #3 on: 11 June 2012, 14:52 »
Standard they do sit far in, if you look at another one they really need a 10mm spacer.
Offline stainesy
« Reply #4 on: 11 June 2012, 14:53 »
his looks like it needs a bloody 20mm one
Offline search
« Reply #5 on: 11 June 2012, 15:45 »
my rear wheels are the same,  i can only assume this is normal for all mk3 being cl gti or anni? like mention spacers will do the trick.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline stainesy
« Reply #6 on: 11 June 2012, 16:13 »
Oh yeah I no its normal on the rears of mk3s but his looks way more that 10mm. There's a big diferance between his and mine.
Offline DfsGTI
« Reply #7 on: 11 June 2012, 21:56 »
My anni wheels ate 7's they sit well in the arches at the rear
10mm spacer sorts them out
Offline dom
  • Back in a Mk4
« Reply #8 on: 11 June 2012, 22:04 »
The offset will be stamped on the inside of the wheel, your best bet is to take one of each off and have a look.
Offline Ess_Three
« Reply #9 on: 12 June 2012, 10:02 »
Anni 7.0" wide RXIIs are ET43.
Mk4 6.5" wide RXIIS are ET42.
..but gaining motorcycles.
