Author Topic: Gearbox oil type question  (Read 3388 times)
Offline javalin
« on: 11 June 2012, 13:40 »
All,
Can somebody confirm that VW oil G 060 726 A2 is the right stuff for a 97 AGG with the std manual 8v gearbox.
Oh and is it a 2.4 litre gearbox?  (i.e. I need 3 x 1 litre bottles?)
James
« Last Edit: 11 June 2012, 13:52 by javalin »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline itavaltalainen
Re: Gearbox oil type question
« Reply #1 on: 11 June 2012, 17:54 »
Castrol guide says 75w90 and 1.9liters for a mk3 2.0 manual
VW to my knowledge have only one oil for all manual boxes, so that should be the right one.
http://www.castrol.com/castrol/iframe.do?categoryId=9033468&contentId=7061486
Offline javalin
« Reply #2 on: 11 June 2012, 17:55 »
ok - the parts guy said they had several types.  Will check Haynes too.
ta
« Reply #3 on: 11 June 2012, 18:02 »
Haynes will tell you that you need G50 75w90 oil from VW 1.9l for 020 and 02K gear boxes (or 2.2l for 02A - but these were only used for diesels and the 2.0 16v). I thought they replaced G50 with G60 oil but could be wrong?
Alternatively just go and get 2l of 75w90 GL-4 spec oil, most likely cheaper than VW pharmacy prices.
Offline mrsaunders
« Reply #4 on: 11 June 2012, 18:08 »
gearbox oil from vw near me is suprisingly cheap for there branding on it
