Author Topic: shakey steering at 80mph  (Read 4018 times)
Offline wheatobear
« on: 10 June 2012, 20:42 »
was on motorway today doing like 80/85mph steering was a little shakey...what could be causing this? got new wheels on so there balanced as far as im aware...anythin else could cause this!?
cheers wheato!
Offline mcgee9t2
Re: shakey steering at 80mph
« Reply #1 on: 10 June 2012, 20:42 »
tracking out
cv joints?
Offline Bandit127
« Reply #2 on: 10 June 2012, 20:48 »
What car and wheels? The sweet spot for out of balance vibration on my Mk3 GTi with original wheels was 75-80 mph. I too thought the vibration was so bad it must be a drive shaft or something.
But balancing at a Protyre place sorted it.  :smiley:
It is also the cheapest place to start...
Offline justalex81
« Reply #3 on: 10 June 2012, 20:49 »
probably not balanced correctly. Are you sure you weren't doing 70mph instead of 85?  :rolleyes: :lipsrsealed: :wink:
Offline wheatobear
« Reply #4 on: 10 June 2012, 20:52 »
alright ill start there...and lol no i was doing 85 .... i speed...everyone does!
« Reply #5 on: 10 June 2012, 21:39 »
If non standard alloys check and make the spiggot rings are fitted all ok.
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 10 June 2012, 22:38 »
 Check centerbore size make sure spiggot rings are correct if wheels are non standard,are you running non hubcentric spacers?
Offline wheatobear
« Reply #7 on: 10 June 2012, 22:53 »
yeah they are non standard.... and only one of my wheels has a spacer on and its not a hubcentric one!
Offline danny_p
« Reply #8 on: 10 June 2012, 23:24 »
mine dose this when there out of balance  usally because there full of mud.
tho last time it was beacsuse the tyer pikey balanced them without removeing the mud  then i pressure washed them   ooops
all the VW's have gone bar 1.
Offline golfyste
  • Project track car
« Reply #9 on: 11 June 2012, 08:20 »
Why does only one wheel have a spacer  :laugh:
