Author Topic: 1.8t warning lights,wont start......timing belt gone =0(  (Read 2140 times)
Offline yickergti
Had a text off my brother this morning saying his his golf wouldn't start last night. He said it was running fine before he parked it up.
Said he tried it 3 times and the 3rd time it flashed up "oil pressure,stop motor" so just left it. Does this sound like the common sludge/pick up pipe problem and would replacement oil pump and pipes cleaned be a good place to start?
Any help would be appreciated
« Last Edit: 10 June 2012, 18:58 by yickergti »
Offline barrym381
Re: 1.8t warning lights,wont start =0(
« Reply #1 on: 10 June 2012, 12:27 »
could be a faulty sensor but i would be droppin the sump to check anyway as its easy enough  :smiley:
Offline yickergti
« Reply #2 on: 10 June 2012, 15:03 »
I would have thought it would still start though if it was just a blocked pipe and then cut out? But then if its the sensor maybe not  :undecided:
Offline yickergti
Re: 1.8t warning lights,wont start......timing belt gone =0(
« Reply #3 on: 10 June 2012, 19:03 »
Well just had the neighbor look at the car and he says the timing belt has gone. Probably slipped its teeth at the bottom  :shocked:
Anyone had this happen to them and if so have an idea of the costs involved? Car wasn't running when its happened so hopefully there isn't much damage.
Offline dom
  • Back in a Mk4
« Reply #4 on: 10 June 2012, 19:07 »
The belt won't have gone with the engine off. You'll have to whip the head off to assess the damage.
Offline mcgee9t2
« Reply #5 on: 10 June 2012, 19:14 »
+1
could be any amount of damage... only real way to find out though is to take it apart and have a look...
Offline yickergti
« Reply #6 on: 10 June 2012, 22:45 »
Is there no other way of assessing for damage apart from taking the head off?
Offline Bandit127
« Reply #7 on: 11 June 2012, 06:42 »
A compression test will confirm the worst. You will need to fit a new belt first for this.
Offline harlemex
« Reply #8 on: 11 June 2012, 15:23 »
how did your neighbour come to this conclusion?
Offline JimBR
« Reply #9 on: 11 June 2012, 15:50 »
I dont see how the cambelt has snapped parked up overnight, youd have known if it had gone when driving and you say it was fine. I reckon its something else personally from what youve said
