Author Topic: new maf, same problem  (Read 1999 times)
Offline KIN9DUB
« on: 06 June 2012, 17:00 »
so i've just been and got a new maf sensor n i'm still getting the problem when i plug the electric plug back in, judering and loss of power then suddenly kicks in, when  removed its fine. could it be the actual plug or something like that?? might have to see about putting it on a vagcom, if that will show up what the fault is? on the up side i went scrappy and got new door strip which was needed and another spare maf sensor and air pipe etc new door handle. 15 rupees. not bad.
Offline tweed
Re: new maf, same problem
« Reply #1 on: 06 June 2012, 18:41 »
Told you to check all pipes after the sensor. If air is getting in after the sensor it will cause it to do that! Get for vacuum pipes etc
Offline KIN9DUB
« Reply #2 on: 06 June 2012, 20:53 »
chill out.. i have checked the pipes etc, fully checked them. i've sorted it now anyway.. cheers
Offline Luke1981
« Reply #3 on: 06 June 2012, 21:05 »
Well what was the problem then?
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Bandit127
« Reply #4 on: 06 June 2012, 21:11 »
Yeah - cough up bud... 3 years from now some poor soul on Google with exactly the same problem as you is going to need the solution.
Offline Shady Pioneer
  • graphic designer.
« Reply #5 on: 06 June 2012, 21:37 »
It's all very well replacing the MAF but you may find that there's a fault code that will still be showing up so get it plugged into VAGCOM and clear the code. :afro:
« Reply #6 on: 06 June 2012, 21:52 »
Or you may find the new maf is faulty
Offline tweed
« Reply #7 on: 06 June 2012, 22:41 »
I'm so chilled my sweat turns to ice.
Caugh up then?
Offline KIN9DUB
« Reply #8 on: 07 June 2012, 16:15 »
i changed all the pipes to the sensor, and the maf sensor and the metal pipe it's attatched to, cleaned all of it aswell with contact cleaner and it seemes to have work. so new maf wasn't faulty, must have been something else. like you said tweed, it could have been the pipes. but changed the whole lot and it's running a lot better, just abit jumpy on the idle. cheers for the help anyway.. :smiley:
Offline tweed
« Reply #9 on: 07 June 2012, 19:12 »
The main thing is it's working  :smiley:
Go have some fun
