Author Topic: Constant clutch slip  (Read 2450 times)
Offline archie837
« on: 05 June 2012, 21:44 »
Help!
Just changed the engine in the mk4 diesel and all good!
Bled through the clutch and everything seemed ok, apart from
The biting point was right at the top.
It moved under it's own steam but as soon as you get to about 2500rpm the clutch slips. It also won't put any power down in anything above 2nd gear.
Will simply rebleeding sort or am I going to have to chuck in another clutch?
Cheers.
Project longterm Airbanger.
PD150 Anni daily
Re: Constant clutch slip
« Reply #1 on: 05 June 2012, 22:04 »
Sounds like you need to replace the clutch.
Offline archie837
« Reply #2 on: 05 June 2012, 22:09 »
The new engine had a new one on there with loads of meat on it.
I am going to be pulling the box off and putting the old one back in to see if that helps.
PD150 Anni daily
Offline danny_p
« Reply #3 on: 05 June 2012, 23:15 »
flywheel chould be fked
all the VW's have gone bar 1.
« Reply #4 on: 05 June 2012, 23:52 »
Check and make sure the crankshaft oil seal is all ok and not weaping
Offline archie837
« Reply #5 on: 06 June 2012, 05:35 »
Crank seal was fine - box wasn't damp at all.
Going to swap clutch and flywheel off the old engine today as I knew it worked.
Thanks for re affirming what I thought.
PD150 Anni daily
Offline vw_tees
« Reply #6 on: 18 June 2012, 00:21 »
Sounds like one of the oil seals are gone, this happened to mines once.
Offline archie837
« Reply #7 on: 20 June 2012, 12:34 »
Ah fixed it the next day by putting in my old clutch and flywheel off the other engine.
Think the guy had replaced the clutch, but not the flywheel - so loads of meat on the clutch, but not enough on the flywheel to engage.
Touchwood no problems since.
PD150 Anni daily
