Author Topic: air filter box  (Read 1095 times)
Offline monty9120
air filter box
« on: 05 June 2012, 20:49 »
i changed my air filter and no matter what on the front of the air box i can still see some of the filter. i didnt check beforehand if it was like that before. it seals everywhere else but because theres no clips on the front i gather this is the reason
anyone else had this problem its a1.8 turbo
Offline daz veedub
  • Operation 1.8t bolf
Re: air filter box
« Reply #1 on: 05 June 2012, 20:57 »
should fully seal all the way round
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: air filter box
« Reply #2 on: 05 June 2012, 20:59 »
pics?
Re: air filter box
« Reply #3 on: 06 June 2012, 00:02 »
Mine was the same, just make sure the top is hooked in and then screw it down.
Offline mrapoc
Re: air filter box
« Reply #4 on: 06 June 2012, 09:37 »
Mine does it too.
I put some self adhesive door insulation stuff (to stop drafts kinda stuff) around the gap.
Dunno if it would affect it that much but I don't have a gap anymore
Offline theshrew
Re: air filter box
« Reply #5 on: 06 June 2012, 12:24 »
Ive had this in the past when ive fitted a new one - You shouldnt see any.
Have fiddle about you will be able to get it to seal correctly.
Offline monty9120
Re: air filter box
« Reply #6 on: 06 June 2012, 16:46 »
i will try and get a pic. i have tried a few times but no luck. it hooks on the back and the front seems to just be able to go where it wants really
Offline monty9120
Re: air filter box
« Reply #7 on: 07 June 2012, 11:30 »
here you go. its all hooked in correctly
