Author Topic: Sump pickup - does it need attention like a Mk2  (Read 1362 times)
Offline Bandit127
« on: 05 June 2012, 20:29 »
I keep reading about Mk2 owners cleaning their oil pickups. Does this also apply to Mk3 engines? Specifically the AGG.
Also - is this a VW design problem? I haven't heard of this problem since the Mk1 Cortina engine...
« Last Edit: 05 June 2012, 20:33 by Bandit127 »
Offline Khare
  • The bear that khares
Re: Sump pickup - does it need attention like a Mk2
« Reply #1 on: 05 June 2012, 20:38 »
Yes.
With age the plastic baffle goes brittle and it chips off, and the bits end up getting caught in the mesh on the oil pick up. It's good practice getting the sump off every few years and clearing it.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2 on: 05 June 2012, 22:15 »
this is a major issue on 1.8T engines too
iv always changed mine frequently, think the last one i got for mine (the S3 engine) was only about £7
sump of job to do tho, mines been off 4 times now due to hitting the ground, so i can do the job in around a hour  :grin:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 06 June 2012, 20:02 »
you should try it on the ssat.... you need to lower the front subframe to get the sump of!!
