Author Topic: cutting plate down.  (Read 4681 times)
Offline mcgee9t2
cutting plate down.
« on: 04 June 2012, 18:34 »
got my us spec rubstrip half sorted as you can see from the pics
however the plate looks a bit big. if i cut the top and two edges off, is that still legal? (not tampering with letter spacing)
Offline mcgee9t2
Re: cutting plate down.
« Reply #1 on: 04 June 2012, 18:34 »
also the bs number is under the a so that will be still on...
« Reply #2 on: 04 June 2012, 21:38 »
I believe they have to be a standard size so any trimming could lead to problems.
« Last Edit: 05 June 2012, 12:31 by Wayne »
Offline JC
  • Back in the North.
« Reply #3 on: 04 June 2012, 21:47 »
cutting / trimming anything off it will make it illegal.  :smiley:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #4 on: 05 June 2012, 09:54 »
Nice rub strip, you going to get it colour coded? How did you do it  :smiley:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 05 June 2012, 12:07 »
I think you're trying to over complicate things, put the plate back to central, but slightly lower, maybe even fit a square type plate, as a US spec car would have. Make some brackets up that mount to the bumper, but hold the plate 20mm off it, brackets should be hidden, and plate attached the the brackets with sticky pads, rather than screws... so it appears that the No plate is floating in the air, just in front of the bumper...   Less is more!
Altering that plate in any way, would just look naff!
Thom
« Last Edit: 05 June 2012, 12:10 by Thom89 »
Offline mcgee9t2
« Reply #6 on: 05 June 2012, 18:25 »
us spec rub strip
Thom
was thinking of making some sort of bracket but wasnt sure.
also cheers for the answers, wownt be cutting it then...
Offline mcgee9t2
« Reply #7 on: 05 June 2012, 18:27 »
another idea i had was a motorbike plate as you can get the smaller sized ones of them i belive. whats the legalities of them, can they be used on cars or not?
« Reply #8 on: 05 June 2012, 22:07 »
They are illegal on a car, not really worth the risk.
Offline scarr89
« Reply #9 on: 05 June 2012, 22:21 »
I mean did you make the rubstrip your self, or did you buy a US one? I thought the US rubstrips didn't fit unless you bought an entire US bumper... :undecided:
