Author Topic: HELP.. CLUTCH RELATED ISSUE!!  (Read 3745 times)
Offline GUMBALL3000
« on: 03 June 2012, 18:16 »
I have just changed the clutch in my Mk3 1.8SE.. All back together.. started it up and its now making a noise as if the thrust bearing was broken, but it was fine before i replaced the clutch.. As soon as i apply preassure to the clutch it goes.. Drives fine etc, just this terrible rattle/knock noise on tick over.
Any help appreciated..
Thanks.
Offline Screech16v
  • MK3 20vt AGU
Re: HELP.. CLUTCH RELATED ISSUE!!
« Reply #1 on: 03 June 2012, 18:29 »
Did you not replace the thrust bearing?
Offline Luke1981
« Reply #2 on: 03 June 2012, 18:48 »
I'm betting NO! :shocked:
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline GUMBALL3000
« Reply #3 on: 03 June 2012, 18:59 »
Well the kit didnt come with one, and there wasnt one on the input shaft.. where is the thrust bearing?
Gavv8
« Reply #4 on: 03 June 2012, 19:02 »
This is going to end in tears... :sad:
Offline dubstar9
  • Back to the Golf scene
« Reply #5 on: 03 June 2012, 19:04 »
Ohhh dear!!!! :shocked:
Offline liva2704
« Reply #6 on: 03 June 2012, 19:04 »
!!AAARRRGGGHHHH!!
Offline dubstar9
« Reply #7 on: 03 June 2012, 19:12 »
This is the 3 piece clutch kit you should have been fitting to your 1.8, note - clutch cover, clutch plate and release bearing which fits on the input shaft and operated by the clutch lever through the bell housing.
http://www.ebay.co.uk/itm/VW-GOLF-1-8-MK3-93-97-VECO-CLUTCH-KIT-/330660839766?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cfcec0156
Offline GUMBALL3000
« Reply #8 on: 03 June 2012, 19:16 »
thats not the kit that went on or came off mine.. it had no thrust bearing on the input shaft.. it was a kit with a little round plate it a big metal ring that held the little round plate on
Offline GUMBALL3000
« Reply #9 on: 03 June 2012, 19:18 »
