Author Topic: Water pump cambelt changed, map sensor changed still not running right  (Read 3195 times)
Offline rench
just picked car up from getting cambelt and water pump done, car not boosting up hardly if not at all, if you drive then put foot down it bogs down then goes but dont boost up
getting code
16490/P0106/000262 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
and
16621/P0237/000567 - Manifold Pressure / Boost Sensor (G31): Signal too Low
any ideas whats caused or causing this and how to fix?
« Last Edit: 05 June 2012, 17:35 by rench »
Offline RTechUK
  • R-TECH OFFICE 01455 617233
getting code
and
What engine you got dude?
Nick
 01455 617233
Offline rench
its AUQ 180
Offline Granta Gti
I would make sure all the sensors are plugged in, could be. Possibility that the timing is out but I'm cant see that not letting it boost.
Offline rench
Dropped car back of at garage and they say it's a sensor or something under washer or coolant bottle forgot which they said now????
Offline rench
Map sensor on manifold Apprently
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
MAP sensor sits on the intercooler under the washer bottle
Offline rench
Any reason why this has gone since water pump and cambelt was done? Was fine before apart from overheating
Offline littco
They probably broke a wire to the sensor when they removed stuff to do cambelt. Implausable signal means little or no signal so suggest it was damaged in the process.
Offline rench
Is it more there fault then dont want to be paying out for a new map sensor if it's there fault
« Last Edit: 03 June 2012, 18:39 by rench »
