Golf mk4
Wazzzer
Water pump cambelt changed, map sensor changed still not running right
Topic: Water pump cambelt changed, map sensor changed still not running right (Read 3192 times)
rench
Here all the time
Re: overheating sorted,Water pump cambelt, now got two fault codes and boost problem
Reply #10 on:
04 June 2012, 13:26 »
Would it just go like that as it was fine day I dropped it of or is it more likely the wirring on it?
http://www.golfgtiforum.co.uk/index.php?topic=228442.0
rench
Here all the time
Re: Water pump cambelt changed, map sensor changed still not running right
Reply #11 on:
05 June 2012, 17:37 »
had map sensor changed, running abit better but still not boosting up fully and still hesitates some times when you put foot down or change gear. also it was backfiring few times on drive home?
could this be timming out?
JimBR
Reply #12 on:
05 June 2012, 18:12 »
Sounds very much like it yes. Seems coincidental that its straight after a cambelt change
Golf mk4
Wazzzer
