Author Topic: SKY HD+ cable problem  (Read 1363 times)
Offline WillGTTDi150
« on: 30 May 2012, 20:38 »
I took the cables out of the back of the box and the "F" pin thingy broke off somehow..... Is it repairable or replaceable? I really don't want to call Sky and pay them
Any help greatly appreciated
Offline tomp
Re: SKY HD+ cable problem
« Reply #1 on: 30 May 2012, 20:42 »
The pin is part of the cable, is it a screw on F connector or a crimp type?
If its screw on, screw it off, restrip the cable and screw it back on - simple....
Ifs a crimp connector, just buy a screw on one...
« Reply #2 on: 30 May 2012, 20:52 »
I think it's a screw on one..... Any idea where to buy one from?
Offline Mikester
  • Civic Type R
« Reply #3 on: 30 May 2012, 21:18 »
If its screw on then you dont need a new one.
You just unscrew it. Re-strip the cable and screw back on.
Same theory as a normal TV arial if you ever done one of them?
Offline Mikester
  • Civic Type R
« Reply #4 on: 30 May 2012, 21:19 »
This link here tells you how to do it with pictures.
http://www.satcure.co.uk/tech/fconn.htm
« Reply #5 on: 30 May 2012, 21:40 »
Cheers mate, I'm off to give it a go......
« Reply #6 on: 30 May 2012, 21:56 »
Works perfectly with the help of that video..... Cheers for that mate, the Mrs will need to find something else to moan about now!!
Top man
Offline Mikester
  • Civic Type R
« Reply #7 on: 30 May 2012, 22:08 »
Top man
No problem. There is always something to moan about!
Its the exactly the same for a normal tv ariel. Can help if you loose freeview channels or get a bad image.
