Author Topic: hub dyno now back from re-map not so happy anyhelp would be great (UPDATE)  (Read 6984 times)
Offline wolfie1981
no just the pipes i need for dv / n75  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
those will be fine mate, you may need a length of 3mm pipe to go from the new DV location to the inlet manifold again too
Offline RTechUK
  • R-TECH OFFICE 01455 617233
IMO all these test should be part of the the remap to make sure the car is fit to tune.    A good cheap smoke tester is around £500, pressure tester £30 and the main on a tourch to do visual inspections.
If you can log blocks 025 this will show whats really going on.
If you do get stuck I am sure my mate Joe will help you at http://www.chippedire.com/  Just mention my name and he will look after you.
Nick
 01455 617233
Offline harlemex
Can he not just fit the new forge valve where the baileys is?
Offline RTechUK
Not a good idea,  have you seen how restrictive the relocation pipe is?
 01455 617233
Offline harlemex
I dont know what the relocation pipe is.  :laugh: :embarassed: Just a thought, as I have the same baileys valve and want to put the standard back on for now in the easiest way. Is it possible to just blank off the location of the baileys valve once its removed?
Offline wolfie1981
nick the phone call i had with you was great help thanks  i am going to buy and put the 007p where it should be for a start and change the intercooler pipe + buy the pipes needed to put the 007p in the stock postion and take it from there the guy who mapped it will run it again for me and log it for free so lets hope doing the bit first helps if not the log should show whats going on
Offline RTechUK
  email me the logs blocks 025 013 and it will help me help u.. :smiley:
 01455 617233
Offline wolfie1981
will do nick but wont be till end of next week some time because of the bank hol's
Offline wolfie1981
still waiting on my pipe work to come :cry: what colour spring will i need to use in the 007p???
