Author Topic: 8v wont start, im out of idea's!  (Read 1074 times)
Offline frank galager
« on: 28 May 2012, 10:04 »
Hello, so  my mk3 8v won't start, it was working fine, i changed the gear box an now it turns over but won't start at all! Its got me stumped!
The fuel pump is working, i took off one of the fuel pipes next to the block an turned on the car an fuel came out so i think thats fine, its also getting spark. Tested that by putting the leads direct in to the coil pack and watched for spark while i turned the car on. Probably not the best methods to use but you can only pi** with the c**k you've got, ay!
When i was putting the thing back to gether, i got the battery leads to the starter motor the wrong way round. Put the one for the starter to the block an visa versa, there was a spark from where it attached the block realised i was a muppet an changed them back over, could this have fried my ECU?
Also my oil light is flashing but it was doing that last time it ran so i dont think its the problem, although i am gonna change the pump an stuff tomorrow.
Last of all my immobiliser was playing up, so when i tryed to start the car after the gearbox change it wouldn't let me, so i have remeved it, i think i've done it right or it wouldn't be getting fuel an the stater wouldn't work right? It was a Sigma.
Things i've done,
Crank sensor
ECU relay
fuel relay
The dissy an plugs are fairly new.
Timings all spot on.
Like i said out of ideas think it might be the ECU but i dont wanna just keep throwing parts at it.
HELP!!
Offline MattJAbela
Re: 8v wont start, im out of idea's!
« Reply #1 on: 28 May 2012, 10:10 »
You've probably done this, but just an idea from when i changed a saxo gearbox...theres a earth lead on the gearbox which i forgot to reconnect and it wouldn't start but would turn over...just an idea?
« Reply #2 on: 28 May 2012, 10:15 »
well there was no earth lead from my gear box, although a couple of looms which i have no idea what they do lol. but there all on. My earth strap from the block to the bulk head did snap, but had a spare also, snapped. cleaned up the two staps an tapped em together as a temporary fix, might be that but, although its a bodge there is still an earth! Maybe its not cutting it, I'll fit a new one tomorrow when i do the oil pump.
Offline MattJAbela
« Reply #3 on: 28 May 2012, 10:23 »
Yeah, could be that mate. Get a new one and give it a try.
I will have a think too mate, if i think of anything i will let you know.
« Reply #4 on: 28 May 2012, 10:24 »
cool cheers buddy. i'll let you know if it solves my problem.
