Author Topic: tight crank after new rings and shells?  (Read 2562 times)
Offline leigh_harty
  • Audi AGU
« on: 27 May 2012, 10:50 »
Put my pistons back in the block with new rings and conrod bearings and couldnt crank it over (by hand)
Took them all back out to check the rings and their all fine
Put piston 1 back in (closest to belt) and tightened it up and the crank is locked again, loosened it and it spun freely, tightened back up and locked again?  :sad: :sad:
Any ideas? bearings oiled up, new ones looked identical to old ones etc
Dont lose your dinosaur!
Offline danny_p
Re: tight crank after new rings and shells?
« Reply #1 on: 27 May 2012, 12:58 »
you've got a tight shell   measure the cranck and look at the bearing to see what size you have
all the VW's have gone bar 1.
Offline leigh_harty
  • Audi AGU
« Reply #2 on: 27 May 2012, 13:03 »
How would i go about this?
Ive got brand new bearings and a crank with 200k on it (hence the reason to change)
Offline spikenipple
« Reply #3 on: 27 May 2012, 16:17 »
You'll need an external micrometer to measure the crank and a bore mic to measure the bearing. Any machine shop/engineering firm should be able to do this for you.
Offline Bandit127
« Reply #4 on: 27 May 2012, 16:27 »
Last (err - probably only) bottom end rebuild I did I found out the hard way that the bearings were all different sizes. That was a Ford Pinto. I had to play around for ages swapping them all around until it all worked.
I can't remember if it was mains, big ends or both.
I only found out later that they are colour coded...
Offline danny_p
« Reply #5 on: 27 May 2012, 23:56 »
my betteing is he has .10 shells and std cranck size
or a slightly worn cranck and got .10 shells but the cranck needs a quick grind so it can run in them
Offline DOA
« Reply #6 on: 02 June 2012, 10:46 »
Look up plastiguage and get hold of some. Its a substance that squashes in a predictable manner and gives a pretty good indication of how much clearance there is in a joint and should give you an indication of where your problem lies without resorting to normal measuring equipment like Micrometers.
Offline dan2252
« Reply #7 on: 02 June 2012, 11:05 »
a mate of mine rebuilt a 1.8t and this happend to him the new shells he got wernt genuine and caused it to go mega stiff he then used other he had laying around which were of better quality and it was back to normal!
MK4 golf 1.8 turbo agu :)
