Poll
S3 inlet onto a mk4 golf 1.8t
1 (33.3%)
2 (66.7%)
Total Members Voted: 3
Author Topic: S3 inlet fit a 1.8T mk4 ?  (Read 13559 times)
Offline rio_gti
Re: S3 inlet fit a 1.8T mk4 ?
« Reply #30 on: 22 May 2012, 23:28 »
Wot the hel is a maf??? I'm having a blond moment
Air mass meter, between tip and air box, registers how much air the engine sucks in!!!
Offline turbokid23
« Reply #31 on: 22 May 2012, 23:29 »
But y change it?? Don't understand is it just for more air??
Offline golf-sib
  • Турботазик
« Reply #32 on: 22 May 2012, 23:49 »
Well you see... Your MUM!
On a serious not, as the turbo get bigger the air that is sucked in increases more and more. Until it reaches a point where the current MAF cannot read the rate of air flow.
Now again, off topic and explain a MAF. All it is, is a heating element where air flows past it, all it does is works out how much the temperature drop is occurring in the current diameter that it sits in and takes into account IAT (intake air temp) & density, does some maths and thats how it works out the air flow. Also when you take the MAF you notice a pug with mesh on it, the mesh is there to smooth (make linear) the airflow to improve reading accuracy.
Back on topic, eventually the MAF reaches its limit due to the way it works as the element can only go so far, so you increase the internal diameter and adjust the ECU to take into account the new area which will effect how it will read the airflow, in short your increasing its maximum airflow range.
Hope this helps
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Ashmond
  • Money, b!tches And Boost
« Reply #33 on: 23 May 2012, 08:43 »
Just seen this. The benefit of fitting an s3 inlet is that if you get all the charge pipes with twin coolers its all a perfect fit and bolt straight on and you don't have to play about with custom pipes and buy a new front mount like me an Toby did but the cooler we got is a beast
Offline turbokid23
« Reply #34 on: 23 May 2012, 08:57 »
Now I get it cheers b!tch  :grin:
Offline golf-sib
  • Турботазик
« Reply #35 on: 23 May 2012, 09:12 »
Don't forget kids he has an AGU so the inlet mani won't match up as it has wider ports, on a AUM it'd work, otherwise its a case of custom mani if he goes for bigger power.
1.8T AGU..
R135
  24
Offline turbokid23
« Reply #36 on: 23 May 2012, 10:01 »
Iv got the manifold for my Aum,, and it fits perfect
Offline p4sty
« Reply #37 on: 25 May 2012, 00:38 »
yours AGU?
then saab reds will work!
get a badger 5 tip aswell  :cool:
what saab red injectors work as theres a few different part no's on ebay !!
also best place to get a 3" maf ?
and b5 tip the best one to go for ?
anyone know if i need a 4bar fpr / uprated fuel pump ?
Offline Toby
  • Car - less
« Reply #38 on: 25 May 2012, 08:03 »
yours AGU?
I'll find the part no for u,
eBay vr6 maff that looks like urs
B5 is by far he best as it stays pretty much 3" ll the way down to the turbo
U don't need a 4 bar but I used a Walbro in tank pump or a s3/ Cupar r pumps work, eBay for them too or the breaking classifieds
Currently down under
Offline p4sty
« Reply #39 on: 25 May 2012, 10:10 »
If you could let me know that would be great as there's a few sets on eBay ..
Which Saab injectors are the biggest cc ?
And where do I get a maf from ?
