Author Topic: Will these wheels fit?  (Read 1597 times)
Offline wrenton
« on: 22 May 2012, 10:50 »
Hi
I'm considering getting some second hand wheels and wondered whether they're suitable for a standard mk4 2.0 GTI.
From eBay:
Q: Hi Can you let me know the offset / et figure on these...it should be on the inside of the rim.
A: hi there, the alloy wheels are Speedline TJX16H2 ET31
Re: Will these wheels fit?
« Reply #1 on: 22 May 2012, 10:51 »
You need to find out the stud patten, it will need to be 5x100
Offline wrenton
« Reply #2 on: 22 May 2012, 10:53 »
They are 5 x 100, so with that offset etc will they fit?
« Reply #3 on: 22 May 2012, 10:54 »
Yes the offset is a little low but they should be fine.
Offline wrenton
« Reply #4 on: 22 May 2012, 10:56 »
Thank you.
What is the affect of using them with low offset?
« Reply #5 on: 22 May 2012, 10:59 »
They will be a lot closer to the arch, factory offset is 37 to 42.
Offline wrenton
« Reply #6 on: 22 May 2012, 11:00 »
Right, so a risk of rubbing.
Hmm, not sure whether to buy them now.
« Reply #7 on: 22 May 2012, 11:03 »
They should be ok but until you try them you will not really know.
