Author Topic: Cambelt kit...cheap version or expensive version  (Read 1847 times)
Offline fishfingerface
Hi all
my 1999 1.8t is on 76k and i though its about time for a cambelt change
i came across this kit
http://www.psituning.com/product.php/19143/ecs_tuning_ultimate_timing_belt_kit___1_8t_150_180_225
For around £174 is this a good idea to buy ...........or can you buy the same kit for less
do you need everything in this kit? / can you get away with anything - Reducing cost
Re: Cambelt kit...cheap version or expensive version
« Reply #1 on: 21 May 2012, 10:58 »
Just get a genuine kit, better in the long run for piece of mind.
Offline AudiA8Quattro
« Reply #2 on: 21 May 2012, 11:08 »
+1 genuine parts or equilavent , doesn't have to be from the dealer.
« Reply #3 on: 21 May 2012, 11:19 »
Is the psi wourth getting...its seems to include everything bar the kitchen sink
ps thanks for you replies Chaps
Offline Bellend
« Reply #4 on: 21 May 2012, 12:12 »
That seems pretty cheap for what you are getting.
I'd be worried about quality. Especially on the waterpump and thermostat side of things, I find cheap ones just don't last as long.
Might seem expensive but really isn't.
Where all my moneys went.
« Reply #5 on: 21 May 2012, 13:48 »
Not really, cheap parts could end up costing you more in the long run.
Offline stfc_gti
« Reply #6 on: 21 May 2012, 16:21 »
buy cheap buy twice
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Chris.
« Reply #7 on: 21 May 2012, 21:53 »
Euro car parts.  About £120 before discount with new tensioner.  Just get a conti-tech belt.
Click For Build Thread
Offline dan2252
« Reply #8 on: 21 May 2012, 22:27 »
or a dayco or gates belt which is what vw use, thats all a genuine belt is, you look on a brand new genuine belt you will find it says gates or dayco 99 percent of the time, you just dont get the 2 year parts and labour warranty
MK4 golf 1.8 turbo agu :)
Offline shaft69
« Reply #9 on: 21 May 2012, 22:46 »
Bit of over kill that kit crank and cam seal, stat housing??
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
