Author Topic: Boost and afr concerns after power run check, one for R-tech  (Read 1971 times)
Offline shaft69
Had power run today wanted check  boost and AFR more than power, found boost falls peaks at around 3000rpm then falls off does really hold boost. Also AFR bit on lean side till hitting high revs over 6000rpm it richens up see pics one for Nick.  :grin:
spec-ko3s
forge actuator
forge tip
forge 007 dv
N249 delete
N75f
velocity stack and intake filter
tyrolsport smic
APR d/p with sports cat
Milltek
APR stage2 map
« Last Edit: 19 May 2012, 16:57 by shaft69 »
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
I'll see if I can find my power run with AFR on it in a sec, I know mine leaned out towards the top as I need to fit my bigger injectors
Offline shaft69
Mine richens up to 11's!!
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
gotta be down to the map then...
Offline shaft69
Looks like custom map on way I think, car goes bloody well too.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
cars always do before they go pop lol
Offline shaft69
Was pooing myself on runs done 8 runs lad knows loads but only does stand ecu maps. Was doing catheram after mine lads races it well nice, 1.8 zetec on jenvey throttle bodies.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline shaft69
Hope not...!!!! :grin:
184 Wallgate, Wigan
WN3 4AL
07966492823.
