Author Topic: Rear beam removal  (Read 1064 times)
Offline andc1
Rear beam removal
« on: 19 May 2012, 12:50 »
Is there a guide? Simple job? Just unbolted or is it all brakes off and re bleed etc
Offline AD1.8T
Re: Rear beam removal
« Reply #1 on: 19 May 2012, 13:04 »
Loads of people say you need to disconnect the brake lines which you dont quick step by step from what i can remember
Get the wheels off and put it on axle stands
Unclip the hard brake lines the just push out from the clips
Theres a little bracket where theres a join in the lines cut a slot in the bracket big enough to slide the smaller pipe out
Remove calipers and tie them to the shock or something but dont bend the lines
Put a jack under the beam to support it
Undo shock bolts
Undo rear beam bolts the go through bushes
Lower jack a bit and remove the beam
DEFFINITLY A 2 PERSON JOB !
Offline andc1
« Reply #2 on: 19 May 2012, 13:42 »
Cool as long as I dont need to take brakes completely off then easy as . Cheers
Offline mcgee9t2
« Reply #3 on: 19 May 2012, 15:05 »
i had to take mine off. but i supose doing what ad said would have worked.
bit of an arse of a job tbh.  enjoy
also theres a guide in the maintenence section iirc. if not theres one of ukmkivs and vw votex.
Offline AD1.8T
« Reply #4 on: 19 May 2012, 15:30 »
Its not too bad with 2 people just take ya time and dont disconect the brake lines and it will be alot easier !
Offline richw911
