Author Topic: Mark 11 1.8 20v turbo engine conversion  (Read 3867 times)
Offline Foxy1989_123
« on: 16 May 2012, 11:48 »
Hi there I am looking for some help really I am thinking about getting a mark 11 golf and putting a 1.8t 20v engine at the moment I have Octavia vrs my question is what would I need to keep to do the conversion or if anyone know of someone that can do it
Re: Mark 11 1.8 20v turbo engine conversion
« Reply #1 on: 16 May 2012, 20:46 »
Use your Octavia as a donor car, that would be a good move.
« Reply #2 on: 17 May 2012, 00:20 »
I will but I need to know what I need to keep
Offline lemski
  • 16v
« Reply #3 on: 17 May 2012, 08:09 »
Engine, looms, ecu.  Then u want a mk3 16v gearbox. And if it was me, carrado pedal box, mk3 shifter. Id also go for g60 front brakes
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 19 May 2012, 01:33 »
why a rado pedal box? why not the 16v box??
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline lemski
  • 16v
« Reply #5 on: 19 May 2012, 07:37 »
Cos as far as im awre the mk3 unit doesnt fit mk2
Offline hc20v
« Reply #6 on: 20 May 2012, 20:47 »
I would run a mk3 derv box (lo ng ratio) it would help with calming the wheel spin and defo fit a good lsd mine was way too wheel spin happy before
brakes bigger the better im running 305 mm with 4 pot bembos best purchase ever u will not regret spending money on good brakes no point having power if u carnt stop it
Offline EsSeX dAn
« Reply #7 on: 20 May 2012, 20:59 »
you can keep yoylur mk2 pedal box and cable clutch but youll want a clutch actuator as found in seat toledos
i think i love you.....
Offline JamesS
« Reply #8 on: 21 May 2012, 13:52 »
The best option is to use the corrado pedal box (mk3 pedal box can fit but has to be modified more than corrado pedal box) because it uses full hyraulic clutch setup. The cable-hydro setup works but it gives a heavier feel than full hydro. All cars are now hydro clutch so if you are going to the effort of the swap you may as well do the full hydaulic setup, it's better. New G60 280mm brakes are more than adequate for road use and allow you to still fit 15" wheels. Bigger brakes obviously have more stopping power but unless you are tracking the car I don't think it's necessary.
If money is not too much of an issue an LSD and diesel box are def worth doing. My mate had a 260bhp 1.8t mk1 and he found it spun up very easily without an LSD.
Rad will probably need some mounts making up for it or you can use a corrado vr6 rad which is a straight swap.
Not sure about the subframes, may need to fabricate/change engine mount positions.
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline Dave_IOW
« Reply #9 on: 25 May 2012, 01:02 »
Doing this at the minute, but haven't got that far, stripping down the 1.8t loom is a right ballache.
Mine is a 1.3 model, which comes with some of the bits you already need.
I'm going mk3 subframe and rear beam as wont fit on 1.3 subframe, using a mk3 16v gearbox & driveshafts, hydro-cable clutch using the Seat actuator.
You can use the 02j box and buy some 100mm output flanges, although need different driveshafts *heard* they are mk1 caddy items.
Brakes are being used from the 16v mk3 too although probably using the mk4 rear calipers.
All what I have heard, but got some people around that know what they are doing  :wink:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
