Author Topic: Conlog alarm fob is annoying me now!  (Read 4856 times)
Offline Shady Pioneer
  • graphic designer.
« on: 15 May 2012, 22:46 »
I have a Conlog alarm in my Anni and for over a year now the remote has stopped working, it's how I used to start the car as it bypassed the immobiliser. Now I have to put the fob into this slot:
This is very tiresome and annoying. I have changed the batteries to no avail.
Does anyone have any ideas on how I can either sort out a new fob or how to stop needing to use the fob to bypass the immobiliser through the above picture?
Thanking you.
Offline off_the_cuff
Re: Conlog alarm fob is annoying me now!
« Reply #1 on: 15 May 2012, 23:31 »
i had that in my vr6 and it done my head in, when my car was locked i pushed the button a few times now i dont need to use it. my car never used to start until u put the fob in but now its redundant. if i remember how i done it ill let u know
  • graphic designer.
« Reply #2 on: 15 May 2012, 23:34 »
If you could remember that would be really helpful, it's such a pain in the ass. Stretching over passengers to turn the bloody car on.
Offline murraymint
« Reply #3 on: 15 May 2012, 23:38 »
Could you not redirect that little port thing to under the steering wheel if you can't sort it? Bit less of a pain every time then
josh
« Reply #4 on: 16 May 2012, 00:26 »
its easy to move, i moved mine to where the obd port is beside the ashtray, its just a clip that connects the wires
Offline madmanmart
« Reply #5 on: 16 May 2012, 12:13 »
The alarm is easy to remove, just find trace where is hacked into you mk3 loom and remove and re-solder.
30 mins work.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline mrsaunders
« Reply #6 on: 16 May 2012, 19:02 »
i have this same problem, dont mind it on my own but with passengers it gets more annoying
  • graphic designer.
« Reply #7 on: 17 May 2012, 19:03 »
Chuffed as nuts right now. Bought some GP4/393 batteries from Grandabatteries, you can find them here:
http://www.granadabatteries.co.uk/gbpremiumcarkeybatteryca2443936v-p-204.html
I had originally bought the same 393s from Maplins that didn't work. Found these via some proper forum searching and took a gamble. Put them in and the remote came to life! Red light on when pressed and checked with the car, and it locks and unlocks like it used too!
Get the f**k in.
Now just gonna wait for the alarm to go off randomly...  :grin:
Offline mrsaunders
« Reply #8 on: 17 May 2012, 20:27 »
Think i'll make a purchase, my fob only has one button will this work on the doors or just the alarm?
  • graphic designer.
« Reply #9 on: 17 May 2012, 20:53 »
Both mate. At least mine did. When locking with the remote it activates the alarm. If it does work you can check the alarm by holding down the button.
My next mission is to get a new remote case as mine is knackered.
