Author Topic: 1.8t 4WD?  (Read 1813 times)
Offline turbokid23
1.8t 4WD?
« on: 15 May 2012, 14:54 »
Is it poss to put a 1.8t mk4 into 4wheel drive? Or has some 1 done this?? Or can you bolt a 4 wheel
Drive system strate on???
« Last Edit: 15 May 2012, 16:43 by richw911 »
Offline km
Re: Info
« Reply #1 on: 15 May 2012, 15:01 »
from what i've read, it would be easier to take the shell and put a new engine in.
http://uk-mkivs.net/forums/t/302090.aspx?PageIndex=1  :lipsrsealed:
Offline barrym381
Re: 1.8t 4WD?
« Reply #2 on: 15 May 2012, 17:56 »
its possible to fit a 1.8t in to a 4mo shell has been done a couple of times now  :smiley:
Offline JimBR
Re: 1.8t 4WD?
« Reply #3 on: 15 May 2012, 17:59 »
Buy an S3
Offline turbokid23
Re: 1.8t 4WD?
« Reply #4 on: 15 May 2012, 18:02 »
Don't like the shape of the s3 do
I have to have the shell or can I just have the parts???
Offline JimBR
Re: 1.8t 4WD?
« Reply #5 on: 15 May 2012, 18:23 »
I think the floorpan is completely different on a 4motion because of the prop ect
Offline barrym381
Re: 1.8t 4WD?
« Reply #6 on: 15 May 2012, 18:23 »
better off startin with a 4mo then droppin a 1.8t in
http://www.youtube.com/watch?v=AM6-eiEwPM0
« Last Edit: 15 May 2012, 18:26 by barrym381 »
Offline Rhyso
Re: 1.8t 4WD?
« Reply #7 on: 15 May 2012, 19:43 »
Do a search as this topic has been covered several times in the last couple of months
Offline turbokid23
Re: 1.8t 4WD?
« Reply #8 on: 15 May 2012, 21:47 »
B reeding all through that post at the top on ukmk,, wot a mission will have to save a good bit of money 1st but wot a car 370bhp in a qwatro gti :)
Offline marcos
Re: 1.8t 4WD?
« Reply #9 on: 16 May 2012, 08:40 »
iv just done the same with my 4mo, not hard to do at all only thing different you need to a normal 1.8t conversion is a quattro exhaust to avoid downpipe and quattro gearbox as v6 boxes will not fit,
