Car audio
best way to route cables from boot to battery
Topic: best way to route cables from boot to battery (Read 3451 times)
monty9120
GTI forum regular
14 May 2012, 20:24 »
hi all whats the best way to route wires for a sub on a mark 4 golf.
the sub will be fitted on the passenger side if that helps
Len
10k hero
Re: best way to route cables from boot to battery
14 May 2012, 20:54 »
Power down one side - amp wires down the other side.
www.sas.org.uk
www.the-ace.org.uk
monty9120
GTI forum regular
14 May 2012, 20:59 »
i meant into the engine bay
H17RBO
16 May 2012, 00:20 »
If you look in engine bay there's grommets leading to behind glovey and near pedals, as said above power on one side, all trim pops off and rear arch trim has a cap you screw off.
monty9120
GTI forum regular
16 May 2012, 13:03 »
i have found the gromet for the wiring loom. just need to wait for the kit to turn up
stuartb3502
16 May 2012, 20:35 »
I have pictures of this if you need help. Let me know and i'll dig out and post.
Stuart
2010 GTD. RNS510 and Bluetooth fitted. Hertz Hsk165xls, Audison Bt ten D, Hertz Hdp 4, Rockford Fosgate mono amp. Hertz 12" sub. VCDS HEX+CAN available Camberley
Golf TDi 130 (Alpine head unit/iPod with Alpine KTP445 in-dash amp. behind glovebox). Mission components front, OEM rears. Kenwood 10" sub and Rockford Fosgate amp in removable box in the boot.
monty9120
GTI forum regular
Reply #6 on:
16 May 2012, 20:44 »
if you have mate, may help others too. many thanks
stuartb3502
Reply #7 on:
16 May 2012, 21:07 »
Just realised I have already posted up on MKIVs. Not sure if posting links is against the rules. If so, I apologise, but just trying to help.
http://uk-mkivs.net/forums/p/299960/2221526.aspx#2221526
Another thread from others here...
http://uk-mkivs.net/forums/t/465016.aspx
Stuart
monty9120
GTI forum regular
Reply #8 on:
17 May 2012, 09:32 »
click on quote and copy the picture links onto here.
Car audio
