Author Topic: TURBO flutter after N249 bypass ??  (Read 14523 times)
Offline Chris#101
Re: TURBO flutter after N249 bypass ??
« Reply #10 on: 15 May 2012, 20:34 »
I did the bypass and then after a week or so it annoyed me, so just scrapped the N249 and N112 delete with the resistors and forge blanking plate and made a massive difference, bay looks much neater.
as for the fluttering, what size tubing did you use and have you cable tied them all on / checked them all ?
What annoyed you about the bypass  :undecided:?
I used 3-4mm & 5-6mm silicon pipe and all are clamped tight to the connectors!
Have you got a link to the N112 delete?  :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline dom
  • Back in a Mk4
« Reply #12 on: 15 May 2012, 21:38 »
This is how mine is set up & I get nowhere near that amount of turbo flutter:
Offline rio_gti
« Reply #13 on: 15 May 2012, 21:50 »
why did no-one remove the metal pipe??  :laugh:
do you leave the valves plugged in so there are no codes that come up??
jockgti
« Reply #14 on: 15 May 2012, 21:56 »
i've binned the lot and have resistors in with no codes,i still have metal plate in that the 249/112 should be on the back of as i used it to hold my catchcan
Offline rio_gti
« Reply #15 on: 15 May 2012, 22:01 »
what resistors did u use?? i know i can search but im being lazy  :wink:
jockgti
« Reply #16 on: 15 May 2012, 22:38 »
10w 330OHM resistors the ones with the heatsinks soldered 2 bits of wire 1 each end,then got some male connectors and cut them to fit the holes,then covered them in electrical tape
Offline rio_gti
« Reply #17 on: 15 May 2012, 22:43 »
simples!!!!  :smiley:
Offline Chris#101
« Reply #18 on: 16 May 2012, 07:42 »
Should I be getting any flutter atall then :)?
How you've routed yours have you left the plugs in the valves or did you put resistors in?
jockgti
« Reply #19 on: 16 May 2012, 09:10 »
I have a pipe from inlet to dv,the other one from inlet to fpr and a t piece on that to boost gauge the 249,112 and all sai gubbins are in a box in the shed.I used 2 resistors for 249,112 but none needed for sai as you get the improper flow code either way.if your removing sai you will need a blanking plate for where the combi valve is
