Author Topic: Xenon coming home lights  (Read 6232 times)
Offline squirrelGTi
« on: 14 May 2012, 09:03 »
Hey guys,
I only just noticed recently that my coming home lights don't seem to be working.
I've set the computer to stay on for 15 seconds. My leaving home, seems to work just fine. The lights are set to Auto, the timer is set to 15 seconds..... Have i missed something???
Cheers guys.
Gone GTi | 3dr | Manual | Carbon Grey | Xenons | Monza 18's | RCD 510 |Rear Camera | Winter Pack.
Offline mike.
Re: Xenon coming home lights
« Reply #1 on: 14 May 2012, 09:16 »
On the MK6 you have to pull the light flasher before you leave the car to activate the coming home lights.
You can change this in VCDS to work the same as the MK5, ie automatic from ignition switch or door open.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Ess_Three
« Reply #2 on: 14 May 2012, 09:23 »
Any idea where to find the setting in VCDS, Mike?
..but gaining motorcycles.
Offline mike.
« Reply #3 on: 14 May 2012, 09:29 »
Here you go  :smiley:
You need to set the coding in the BCM as below, for automatic operation.
BIT2 set to 0 means it works like the MK5
BIT0 sets the timer to start from ignition off or door opening
Offline squirrelGTi
« Reply #4 on: 14 May 2012, 09:39 »
I'm a total idiot. Yes that's it, i totally forgot!
Would be nice to have come on automatically, so might get it programmed one of these days.
Cheers guys, can always count on the forum to come up with the answers!
Offline Ess_Three
« Reply #5 on: 14 May 2012, 09:47 »
Mike,
Which module is that in?
Central convenience?
Offline mike.
« Reply #6 on: 14 May 2012, 09:52 »
Yep,  Address 09
Offline Ess_Three
« Reply #7 on: 14 May 2012, 09:55 »
Good man...thanks!
Armed with print out and laptop...off I go!  :grin:
Offline mike.
« Reply #8 on: 14 May 2012, 10:18 »
Good luck, see you on the other side  :laugh:
Offline Ess_Three
« Reply #9 on: 14 May 2012, 14:24 »
I can't get the coding to work on my car.
I can change the method of activation from ignition off to door opening (Bit 0)...but it will not do it automatically (Bit 2)
I have to flash the lights in order to kick the sequence off.
I've tried and tried...but it's not having it.  :sad:
If I set Bit 2 to 0, nothing happens at all, regardless of a flash before getting out of the car.
Hmm...any thoughts?
