Author Topic: 1.6 16v 2001 engine cover removal and clocks replacement.  (Read 1371 times)
Offline birch
can someone tell me how to get the engine cover off my 1.6 16v 2001 please, i need to change the water temp sensor and hope it will give me a little more room, thanks.
« Last Edit: 13 May 2012, 08:05 by birch »
Offline richw911
Re: 1.6 16v 2001 engine cover removal
« Reply #1 on: 12 May 2012, 20:00 »
I believe they just pull off on that engine  :smiley:
Offline navmk4gti
« Reply #2 on: 12 May 2012, 23:22 »
put foot on it and pull hard as you can  from top  :smiley:
 :grin:
 should be clips mate on corners twist them and they will pop up  :wink:
Offline dan2252
« Reply #3 on: 12 May 2012, 23:34 »
i think they pull off as these guys said. its the 1.4 thats got 6 mm allen keys in them isnt it?
MK4 golf 1.8 turbo agu :)
Offline birch
Re: 1.6 16v 2001 engine cover removal, clocks replacement.
« Reply #4 on: 13 May 2012, 08:04 »
thanks, it does pull off, it was just really tight. im changing the temp sensor because the temp guage on the dash doesnt work, im hoping this will get the guage working again, if it doesnt and i buy a set of clocks off ebay can i just swap them? will they pick up my mileage reading from ecu? im told the clocks might need to be coded, thanks.
Offline xtetx
Is it running right? A common fault is the temperature sensor! As for the clocks they will need coding back in with your current mileage. A few lads on here can do it. I have some 1.6 clocks hanging about if you temp sensor doesn't resolve the problem.
