Author Topic: Help wiring amp MK5 GTI  (Read 3804 times)
Offline magsmagsmags
  • Mk4 Golf GTI 1.8T (AUM)
« on: 11 May 2012, 22:21 »
Hello
Recently upgraded to a mk5 golf Gti, the previous owner had kindly left me wiring in for a sub / amp so i slapped mine in to find it didn't power on or play sound from the stereo
I followed the wires round the car and realised that the remote wire and red / white audio cables weren't connected to anything, so i ripped apart my dash to get the stereo out only to find there is no connection on the back for sub out or rear out - the stereo in question is one of the touchscreen VW jobbies.
What's my best option here? I know the remote wire can be connected to the stereo power, that's not an issue (although it would be handy if someone could tell me what wire to splice into)
Just need to know what to do about the audio cable?
Thanks
~Mags~
Offline stuartb3502
Re: Help wiring amp MK5 GTI
« Reply #1 on: 16 May 2012, 20:52 »
You need a line out converter (LOC).  You connect your speaker outs to that and it gives you a line level audio signal.  That's assuming you dont have an amp. which can take speaker level signals?
You can get LOCs which will auto detect the signal and give you the remote turn signal also.
A more expensive option is to go for a signal processor such as a JL Cleansweep, Audison Bit ten or Audio control lc2i.  The advantage of these is that they flatten the audio signal (the Vw units have tone crves applied) so that you have nice clean flat signal.  You could go to one of these if the LOC doesnt give you a sound you like.
S.
2010 GTD.  RNS510 and Bluetooth fitted.  Hertz Hsk165xls, Audison Bt ten D, Hertz Hdp 4, Rockford Fosgate mono amp. Hertz 12" sub.  VCDS HEX+CAN available Camberley
Golf TDi 130 (Alpine head unit/iPod with Alpine KTP445 in-dash amp. behind glovebox).  Mission components front, OEM rears.  Kenwood 10" sub and Rockford Fosgate amp in removable box in the boot.
