Author Topic: sloppy gears  (Read 7381 times)
Offline D Squared
sloppy gears
« on: 11 May 2012, 06:43 »
Hi All,
Just wondered if a common fault?
My MK3 GTi 8v has developed a very sloppy gear stick this morning? haven't looked at it yet, just trying to get a heads up on it? I can still get all the gears at the mo, but when engaged the stick has loads more movement than normal...
Anyone else had the same issue?
MK3-MK5- Now MK7 GTi
Offline lemski
  • 16v
Re: sloppy gears
« Reply #1 on: 11 May 2012, 07:36 »
Buishes in the linkage, get a repair kit of ebay. Shouild sort it
Offline Dogbot
Re: sloppy gears
« Reply #2 on: 11 May 2012, 08:35 »
As above I did this and at the same time installed the shorter selector from a corrado it's about an inch an a half shorter makes it feel mouth more direct also has the feeling I've shortening the throw of the change as the std one I found was a bit long.. , it's lovely now, by it's nature the cable selector will have some slop in the but not much, it's certainly not like the mk2 which feels like loading a rifle
Offline lemski
  • 16v
Re: sloppy gears
« Reply #3 on: 11 May 2012, 10:43 »
That's y my mk2 had the mk3 wieghted rod, made it much nicer.
Offline seyles
Re: sloppy gears
« Reply #4 on: 11 May 2012, 13:02 »
I had this happen, it was the 'golf ball' on the gearshift relay shaft.
It breaks down and eventually falls apart leaving you with massive play in the shifter.
You can replace the plastic part without having to take the full part out; it's tricky but doable.
The one I bought; http://www.ebay.co.uk/itm/350564433810
Good luck.
Offline D Squared
Re: sloppy gears
« Reply #5 on: 11 May 2012, 13:21 »
Good luck.
having looked at it under the bonnet it does indeed look like the relay shaft ball has significantly reduced in size....trying to upload image...
Offline D Squared
Re: sloppy gears
« Reply #6 on: 11 May 2012, 13:43 »
how do i upload pics?
« Last Edit: 11 May 2012, 13:48 by D Squared »
Offline D Squared
« Last Edit: 11 May 2012, 14:07 by D Squared »
Offline search
Re: sloppy gears
« Reply #8 on: 11 May 2012, 14:18 »
my gears have gone strange its as if its hard to get in to gear. it moves fine but just the last little bit a bit sticky.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline seyles
Re: sloppy gears
« Reply #9 on: 11 May 2012, 14:46 »
That's the thing, yours has completely fell off, probably broke up.
If you get the part above, you can pull off the 'ball' and push it onto the one on the car (saves a lot of effort).
You have to remove the nut at the top, then wiggle the gear lever in the car to get access.
You won't believe how nice the gear changes will feel after you change it!
« Last Edit: 11 May 2012, 14:49 by seyles »
