Author Topic: sloppy gears  (Read 7382 times)
Offline D Squared
Re: sloppy gears
« Reply #10 on: 11 May 2012, 15:51 »
having looked at it under the bonnet it does indeed look like the relay shaft ball has significantly reduced in size....trying to upload image...
That's the thing, yours has completely fell off, probably broke up.
If you get the part above, you can pull off the 'ball' and push it onto the one on the car (saves a lot of effort).
You have to remove the nut at the top, then wiggle the gear lever in the car to get access.
You won't believe how nice the gear changes will feel after you change it!
ah yes, thanks for putting pic up as well... i have already taken it apart and fitted a aluminuim fitting to get me going, now quite stiff change... so yes will order proper thing.
Thanks guys.
MK3-MK5- Now MK7 GTi
Offline Dolly
Re: sloppy gears
« Reply #11 on: 11 May 2012, 20:38 »
Offline D Squared
Re: sloppy gears
« Reply #12 on: 20 May 2012, 10:50 »
update, so got the new relay shaft from veedubmachine, but they they were very poor at getting back to me via ebay...ended up ordering direct from their webite, which arrived quickly and had good communication.
When i come to fit the part, i decided to change the whole shaft, rather than just the ball. I then realised the shaft was supported via a plastic bush top and bottom, of which the bottom one had siezed to the shaft. I got one of these turned up at work, and then fitted that with the new shaft, the top plastic bush was ok.
So in summary veedubmachine are good, and if fitting a relay shaft complete be ready to replace the plastic bushes that support it.
Gear shift is slick now, thanks for all the advise.  :smiley:
186K valver and still going...
DD
