Author Topic: car is sitting funny  (Read 2935 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: car is sitting funny
« Reply #10 on: 10 May 2012, 07:34 »
Not enough to noticeably see a comparable height drop I wouldn't have thought. The struts aren't the issue anyway, just the front springs.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #11 on: 10 May 2012, 13:57 »
do you have the adjustable plates on the rear? usually it can be lifted or lowerd using a circlip and moving the plate.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline gizmomk3
  • on my way
« Reply #12 on: 10 May 2012, 18:31 »
I do not know getting tracking done tomorrow so will have a look when she is in ramps where would I find it as I do not remember seeing anything like that
Offline SCO_VAG
  • www.ScottishVag.com
« Reply #13 on: 10 May 2012, 20:04 »
The circlip will be on the shock itself.. sitting in a groove.
Offline gizmomk3
  • on my way
« Reply #14 on: 10 May 2012, 20:27 »
Did not see any clip on strut when I took it apart to fit the lowering spring
Gavv8
« Reply #15 on: 10 May 2012, 20:30 »
Should be on the actual piston part of the shock.
« Reply #16 on: 10 May 2012, 20:35 »
No, adjustable spring plates slid up or down the outer strut casing and are held in situ with large circlip. My rear weitec shortened struts have these for fine tuning the ride height to match the fronts.
« Last Edit: 10 May 2012, 20:36 by thai-wronghorse »
Offline gizmomk3
  • on my way
« Reply #17 on: 10 May 2012, 21:19 »
got any pic's you have lost me  :laugh: :laugh:
Gavv8
« Reply #18 on: 10 May 2012, 21:23 »
Sorry, yes wasn't thinking straight.
Gavv8
« Reply #19 on: 10 May 2012, 21:25 »
The large cup that the base of the spring sits in will be adjustable on struts that have this feature, you move the base up and down and it is locked in place by a circlip that fits in the body of the shocker.
