Author Topic: car is sitting funny  (Read 2934 times)
Offline gizmomk3
  • on my way
« on: 09 May 2012, 23:33 »
lowwerd my car a few weeks ago droped it 40mm put new struts on the front but now the back is lower than the front what can i do to sort this??
Offline spikenipple
Re: car is sitting funny
« Reply #1 on: 09 May 2012, 23:36 »
Drop the front more  :laugh:
Offline gizmomk3
  • on my way
« Reply #2 on: 09 May 2012, 23:41 »
thort of that but 60mm drop on the front would look mint but iv got killer speed bumps by me and i have to go super slow with a 40mm drop
was thinking spring spacers/ bumpstops what you lot think??
um less any one has a set of front springs with a 60mm drop that thay want to give me :laugh: :laugh: :laugh:
« Reply #3 on: 09 May 2012, 23:50 »
Sounds like you have the wrong front springs fitted.
Offline gizmomk3
  • on my way
« Reply #4 on: 10 May 2012, 00:05 »
the car shuld be lowerd 40mm all round i got new front struts for a deasle mk3 that makes the handeling amszing never had anything respond so well  :laugh: but the back are used of a git still still but used can i put the standerd springs back on the back??
or will it handle loke sh!t??
« Reply #5 on: 10 May 2012, 00:09 »
What engine is you car, if it is a GTI then diesel springs will be no good due to engine weight.
Offline gizmomk3
  • on my way
« Reply #6 on: 10 May 2012, 06:50 »
1.6 8v  can I put standees springs back on the back with 40mm drop in the front??
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 10 May 2012, 06:52 »
Well there's your problem, wrong spring rate. Diesel engines are quite a bit heavier than 1.6 petrol ones.
« Reply #8 on: 10 May 2012, 06:55 »
Either source the correct springs or at least stick some lowering spring caps on the front. If you're lucky you might get another 10mm drop. I wouldn't put the standard rear springs back on though as it'll look like a hot rod and handle sh!t.
« Last Edit: 10 May 2012, 06:58 by thai-wronghorse »
Offline gizmomk3
  • on my way
« Reply #9 on: 10 May 2012, 07:02 »
Will thay get softer over time just only cost me £10.50 for bilstine ftruts and the handling as good
