Author Topic: Where have you mounted your external bluetooth mic's?  (Read 3102 times)
Offline NotMyName
Sold my brother my old Alpine CDE-103BT which has an external mic & he wants me to install it into his MK4 Golf.
I had it in my MK4 Astra. Originally i had it wired from the rear of the HU, running behind the speedo clocks, out the side of the dash, up the A pillar & stuck at the top of it. It kept working loose though, so i ran it the opposite way, behind the glovebox, up the rubber strip, behind the headlining & attached to the rear view mirror.
All was a doddle & helped massively by there being a hole & blanking plate type thing at the side of the dash.
There's no such hole in the Golf though & i don't know much about taking a Golf apart.
One idea was stuck onto a blanking plate just below the centre heater vents, but i'm not too keen on this idea. It's best to be somewhere out of sight & can't be knocked. I don't fancy taking the speedo clocks out because 1) i don't know how to 2) in case they need programming. The glovebox, like the Astra, looks a doddle, but then there's no hole at the side of the dash to feed through.
What have you done & which is the easiest method?
Offline stuartb3502
Re: Where have you mounted your external bluetooth mic's?
« Reply #1 on: 16 May 2012, 20:42 »
I had mine in the blank you mentioned.  It worked well and was very easy to fit.  Never got knocked.
http://tdi130.files.wordpress.com/2012/03/dsc_0642.jpg
It was a cde103bt as well  :smiley:
S.
2010 GTD.  RNS510 and Bluetooth fitted.  Hertz Hsk165xls, Audison Bt ten D, Hertz Hdp 4, Rockford Fosgate mono amp. Hertz 12" sub.  VCDS HEX+CAN available Camberley
Golf TDi 130 (Alpine head unit/iPod with Alpine KTP445 in-dash amp. behind glovebox).  Mission components front, OEM rears.  Kenwood 10" sub and Rockford Fosgate amp in removable box in the boot.
