Author Topic: I do like a good swim!  (Read 3603 times)
Offline Roverdose
  • So long and thanks for all the fish!
« on: 06 May 2012, 17:40 »
My car is full of water, thought i'd fixed it with a new door seal, i've noticed it only fills up with water when the front is facing down hill, anyone got any ideas of where i can start looking? its only the passenger footwells and the heater matrix is good.
many thanks
ian
Offline X4MGS
  • VAG Parts SNOB!!!
Re: I do like a good swim!
« Reply #1 on: 06 May 2012, 17:42 »
Door Membrane.... Same as mine....
For More Info Click To See;
Offline mikemk4gti
« Reply #2 on: 06 May 2012, 17:43 »
Sunroof water drains blocked maybe?
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 06 May 2012, 17:47 »
Other option is the Scuttle - Loose Cover where the blower motor is, or leaf cover seal gone..
I felt the bottom of blower motor whist it was peeing it down so i know it wasn't that, felt the bottom of the door cards and they were sodden - left to dry out and then fix the membrane... (AGAIN!!)
Offline Roverdose
« Reply #4 on: 06 May 2012, 17:58 »
Scuttle is all good, checked it already and i havn't got a sunroof, doorcards seems like a good first port of call! I've got 4 days off so i know what i'm doing tomorrow! Pray for dry weather chaps!
Offline mush
« Reply #5 on: 07 May 2012, 09:59 »
x2
one of many issues, there was a puddle in mine to, sealed door card and main door, seems ok for now.
MK2 golf 16v :-)
Offline Roverdose
« Reply #6 on: 07 May 2012, 16:50 »
i've put this up in my project thread but thought it might be of interest here
my in car pool
Tell tale signs
rear door before
after
took the oportunity to grease up the window runners and clean out the holes for the water to drain out
Front door was the worst, only a couple of cm's at the top were still bonded
after
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 07 May 2012, 17:00 »
Good Job....
Whats special about the tape you used?
I've tried Gaffa Tape - but it doesn't seem to last... So looking for something that will...
Offline Mr Blue
« Reply #8 on: 07 May 2012, 17:34 »
Get some Second Skin sound deadning and cover both inner and out skins. Water tight and less road noise.
You might want to rip that carpet up and dry the soggy under lay or you will have a hole in the floor by next year  :sick:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 07 May 2012, 17:41 »
Just found 3M's site - http://solutions.3m.co.uk/wps/portal/3M/en_GB/Tapes-and-Adhesives/Home/
& I've ordered some free samples... (Worth a crack and free to anyone who runs a business!!)
I Will talk to their rep and see what they would recommend for the job...
