Author Topic: Engine decarbonazation  (Read 4811 times)
Offline Khare
  • The bear that khares
« on: 05 May 2012, 14:58 »
Was watching wheeler dealers last night and Edd used a machine to clean the inside of the engine. Watch the video in the link.
http://www.discoveryuk.com/video/share/uk/wheeler-dealers-webisode-3/
Interesting I thought, so I searched around and found another way of doing this, using water and nothing more. Apparently it's been around for years.
http://www.youtube.com/watch?v=tt7IY0keOD0&feature=related
I also found a product which is called seafoam which supposedly is used in the same way, and it's supposed to work absolute wonders. Shame it's £20 to buy here in the UK, because in the US it's only a couple of quid.
I'm tempted to try the water method, but using a spray bottle to spray a fine mist of water in rather than a jet of water.
Offline Khare
Re: Engine decarbonazation
« Reply #1 on: 05 May 2012, 20:46 »
This is the result of a water leak (right cylinder) steam cleaning a cylinder over time
« Reply #2 on: 05 May 2012, 21:52 »
Seems a crackpot idea to me  :undecided:
Offline Khare
« Reply #3 on: 05 May 2012, 22:08 »
That's what I thought, but the more I research it the more I'm realizing I can't find anything negative (apart from hydrolocking, which with a fine mist is near impossible to do at fast idle). I'm going to give this a try right before I change my plugs. From reading about how it's done it can take anything between 2l or 3l up to 20l of water to finally get clear water coming out of the exhaust. If you think about it, lots of turbo cars have water injection installed, and a few cars from 30+ years ago also had small water bottles under the bonnet that were slowly added to the cylinder to clean it to keep it in tip top condition. Plenty of stories of mechanics doing this to rough running engines prone to carbon build up and running like a dream afterwards.
Offline tshirt2k
  • Been there...Done that...
« Reply #4 on: 05 May 2012, 22:55 »
Water works. I was interested in that machine too on wheeler dealers.
Mk3 ABF 16VT Megasquirt V3
Offline Seanl
« Reply #5 on: 06 May 2012, 07:36 »
Saw that too. Would be very interested if you go ahead with it to see the results.  :cool:
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #6 on: 06 May 2012, 07:40 »
I seen this wheeler dealer episode too, and thought it was quite fascinating, will also be interested to see how well it works
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline danny_p
« Reply #7 on: 07 May 2012, 00:43 »
rember been show that trick meany years ago.
when the old mans s1 v8 landrover  used to have it's pre mot tune up stage 1 used to involve hanging a coke bottel full of water off the open bonnet with a bit of string  and stabbing pin holes in the bottom of it  so water leacked out into the open throated carb beneath.
modern engines dont really need such fuss or bother unless theres something really up.   but cheepo wall paper steamers  can be adjusted to be used for such uses
all the VW's have gone bar 1.
Offline richw911
« Reply #8 on: 10 May 2012, 18:02 »
I found this link http://www.terraclean.co.uk/  :smiley:
Offline Khare
« Reply #9 on: 10 May 2012, 18:06 »
Yeah I saw that link when I started looking. Looks like an expensive machine though, doubt every single garage will have one.
