Author Topic: Engine decarbonazation  (Read 4824 times)
Offline Khare
  • The bear that khares
Re: Engine decarbonazation
« Reply #10 on: 10 May 2012, 18:11 »
And although it's a very effective machine, the cost of £70+ is a shame  :sad:
Offline danny_p
« Reply #11 on: 10 May 2012, 21:17 »
had a bit more of a read up about it and the bullsh!t alarm is almost about to go off.
basicly all it's doing is fueling the engine with something thats not petrol i see a lot of hype about something thats probaly not all that.
on a direct injection engine its not going to clean the crap out the manifolds or ports ( mainly baked oil residue from the block breather )
as you see they pull the fuel return line  my guess be they are useing a diffrent fuel at a higher pressure.
50p says its a mixture of alcohol and solvent   probaly acetone and ethanol or something allong those lines
all the VW's have gone bar 1.
Offline DOA
« Reply #12 on: 15 May 2012, 13:05 »
Water works just fine, just unhook a vacuum line and drop it in a bottle of water. If the engine tries to bog, pull it out quick.
Offline Khare
« Reply #13 on: 15 May 2012, 19:12 »
Yeah I think that's what I'm going to do. Going to unhook the vac line that goes to the airbox.
Will try and do it in the next week or so  :smiley:
Offline Agreeable Slick
  • Unit
« Reply #14 on: 15 May 2012, 19:28 »
95% certain there is an ethanol mix going through.
