Author Topic: Need some help!  (Read 4305 times)
Offline Aarons golf mk3
Need some help!
« on: 03 May 2012, 17:20 »
1.6 cl golf mk3  keep cutting out when you drive and stop engine know that it could be its doing my nut in help me thank
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Need some help!
« Reply #1 on: 04 May 2012, 06:47 »
Are you turning the key anti-clockwise in the ignition when you stop by any chance?
Offline stainesy
Re: Need some help!
« Reply #2 on: 04 May 2012, 08:24 »
:grin: :grin: :grin: :grin:
Re: Need some help!
« Reply #3 on: 04 May 2012, 13:36 »
 :sick: that's a big help from you dumbo its stop cutting out as if you dum ass
Offline stainesy
Re: Need some help!
« Reply #4 on: 04 May 2012, 13:39 »
do you mean it drives ok but when you stop it cuts out?
if so does it do it more when the car is warmed up to running temp?
Re: Need some help!
« Reply #5 on: 04 May 2012, 14:00 »
No mate when it drives and stops
Offline stainesy
Re: Need some help!
« Reply #6 on: 04 May 2012, 14:05 »
right ok so it starts but the engine cuts out when driving?
does it idle without cutting out?
what is the normal situation when it cuts out?
Re: Need some help!
« Reply #7 on: 04 May 2012, 14:25 »
It got a new idle in it  goes up and down on idle then rev up on its own and cuts on idle but I am driving it mate it just shut down then it takes along time two restart the car mate
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Need some help!
« Reply #8 on: 04 May 2012, 14:29 »
so the car is running fine but the engine cuts out when you are driving or when you drop to idle ?  because you say engine is cutting  out when you "drive and stop engine"  doesn't quite make sense i think i know what you mean does it cut out cleanly or does it splutter then die ?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Rmachines
Re: Need some help!
« Reply #9 on: 04 May 2012, 14:31 »
i give up
