Author Topic: Can anyone te if these are standard sized brakes?  (Read 3075 times)
Offline DaveHDi
I know this might not be possible from this pic but the front calipers on my new GTi are almost touching the inside of the standard wheels. Just wondered if this is normal or do they look like they've been upgraded
Offline Screech16v
  • MK3 20vt AGU
Re: Can anyone te if these are standard sized brakes?
« Reply #1 on: 02 May 2012, 18:22 »
Standard 288
Offline trog_nfs
« Reply #2 on: 02 May 2012, 18:27 »
Normal. Its surprising how tighter fit the standard brakes are to 15s
Offline DaveHDi
« Reply #3 on: 02 May 2012, 18:36 »
Lovely. Thanks guys
Offline gasketface
« Reply #4 on: 02 May 2012, 19:27 »
just remember not to have any stick on wheel weights fitted on the inside when you have new tyres.
I found out the hard way !. :smiley:
« Reply #5 on: 02 May 2012, 22:06 »
Yep standard 288's, just for info drilled discs are not the best idea they tend to crack around the holes
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #6 on: 02 May 2012, 22:21 »
they kill your pads too
plain discs all the way
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline DaveHDi
« Reply #7 on: 02 May 2012, 22:52 »
I'll bare that in mind. Cheers mate
Offline Ess_Three
« Reply #8 on: 03 May 2012, 09:35 »
That's the point though, its't it?
Personally I wouldn't run drilled because they crack (and it doesn't matter if the discs have cast in strong points round the discs...they still crack...911 turbo discs still crack round the holes) but grooved only offer a tangible benefit on brakes that are used hard, especially with more track biased pads.
..but gaining motorcycles.
Offline F17BAD
« Reply #9 on: 03 May 2012, 19:17 »
the point to drilled discs ?
no i wouldn't say they were their to kill your pads prematurely (if this is what you mean?)
They are their to supposedly help heat dissipation.... or thats what i believe
