Author Topic: Launch Control..  (Read 4285 times)
Offline mk3.owner
Launch Control..
« on: 02 May 2012, 14:50 »
How is Launch control fitted.? This was the big conversation over the weekend between me and a few mates.
So just to clear up and argument.. How isit installed on 'JDM' cars such as Civic.. Prelude etc etc. A few lads said it was mapped into the ECU but others were saying you have to buy a control unit that you install in the cockpit.
Any info.?
Offline mcgee9t2
Re: Launch Control..
« Reply #1 on: 02 May 2012, 16:05 »
Depends on the car. im sure mk4s can have it programmed into there ecu. but i suppose cars with older ecus would have to have a controll unit as the basic ecu wouldnt be able to cope
« Last Edit: 02 May 2012, 17:06 by mcgee9t2 »
Offline golf-sib
  • Турботазик
« Reply #2 on: 02 May 2012, 16:53 »
7.5 ecu onwards have it if the ecu tuner puts it in. Early mk4 dont have it due to the Bosch 3.8 ecu. All it is, is at a specific rev range you can trigger the ecu to demand a load and pre spool the turbo meaning your on full power and your off and the traction control does the rest. I imagine other cars do it alike whether na, super or turbo charged.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline golf-sib
  • Турботазик
« Reply #3 on: 02 May 2012, 16:59 »
basically depends if the ecu can be tweaked to do it or not. If not then you have to achieve it by other means. Like said the Bosch 7.5 ecu can ,not sure what other ecu's can and can't do.
1.8T AGU..
R135
  24
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 02 May 2012, 17:05 »
doesn't have to be 7.5.. i'm sure the 7.1 does it too!
Offline mk3.owner
« Reply #5 on: 02 May 2012, 17:21 »
Just as ive seen a Honda Prelude 2.2 Vtec for sale.. Up for £500 but rekon i could get it for about £300. Got 1 month MOT but no Tax. Tidy car.
Was thinking about buying it and making it in to a JDM show car. I did abit more research and found a '2 Step' system (Anyone know anything about them) that causes the car to Pop and bang with a few flames.
http://www.youtube.com/watch?v=RZ8-LolbNQM
Offline golf-sib
  • Турботазик
« Reply #6 on: 02 May 2012, 21:10 »
Settle the argument on the strip down thurrock or excel  :wink:
1.8T AGU..
R135
  24
Offline JulesS3
« Reply #7 on: 03 May 2012, 12:24 »
I had launch control with KPRO on my CTR. Used to force the revs to sit at a set rpm when the clutch was pressed.
Offline jimbooboo
  • YUM YUM
« Reply #8 on: 03 May 2012, 13:06 »
Your better of buying an oil drum, filling it with all your money. Pouring petrol on it. Lighting it. And then pissing on it while your watch all your money disappear.
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #9 on: 03 May 2012, 14:42 »
In all me7.1 512k files I have tried to do there is one 1x1 map missing to trigger the full LC settings.  but saying that I found away to do it on Med9 with one map short by using another maps to fool the base limiter?   I will need to play a bit more but the 7.1 stuff we dont see much of, just in ARZ Golf Ibiza cupra and early TT S3
 01455 617233
