Author Topic: Help! Car won't start :(  (Read 4903 times)
Offline mikemk4gti
« on: 01 May 2012, 18:29 »
Had a few moments spare so thought I would check over my earths on the gearbox and pos connection on the starter. I had the battery disconnected for about 20 mins.
Put it all back together, and now it won't start. The fuel pump is staying on constantly and it has filled the cylinders with petrol. I've took the fuel pump fuse out and spark plugs. I'm getting a spark ok. Have I wrecked the ecu somehow?
It's a 8v digi2 btw.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline tomp
Re: Help! Car won't start :(
« Reply #1 on: 01 May 2012, 19:46 »
Yep sounds like the ecu is blown, same symptons as when I blew one once on an 8v
You will have to change the ECU and do an oil and filter change as the petrol will seem into the oil....
Offline mikemk4gti
« Reply #3 on: 01 May 2012, 19:50 »
Oil and filters not a problem. But don't want to change the ecu until I know whats caused it incase it happens againn as soon as I plug a new one in (which I don't have :( )
Offline mikemk4gti
« Reply #4 on: 01 May 2012, 19:51 »
Checked your relay?
Fuel pump relay? Surely that wouldn't allow it to bypass the injectors if they were closed?
Offline clipperjay
« Reply #5 on: 01 May 2012, 19:53 »
Checked your relay?
Or stuck open?
Trying simple things for you!
Offline tomp
« Reply #6 on: 01 May 2012, 19:55 »
I'd put money on it being the ECU, I did it when I was changing a gearbox, cylinders filled with petrol the same, bought one on ebay for about a fiver, problem solved...
Where in North Wales are you?
Offline mikemk4gti
« Reply #7 on: 01 May 2012, 19:56 »
Ok, it's worth a try as I've got a spare one here, thanks.
Offline mikemk4gti
« Reply #8 on: 01 May 2012, 19:57 »
Colwyn bay
Offline tomp
« Reply #9 on: 01 May 2012, 20:01 »
Don't forget to connect the positive first when reconnecting the battery...
Colwyn Bay is a bit far, could have lent you an ECU out of an 8v that I have here, pretty sure there is a guy on ebay who breaks mk2's in Colwyn Bay though
