Author Topic: Help! Car won't start :(  (Read 4888 times)
Offline mikemk4gti
Re: Help! Car won't start :(
« Reply #10 on: 01 May 2012, 20:03 »
Ha ha, that's me that's breaking one on eBay, but not got an ecu.
Where are you?
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline tomp
« Reply #11 on: 01 May 2012, 20:08 »
Where are you?
Oh right, no use there then!
Offline bodga
  • F reg GTI 16v
« Reply #12 on: 01 May 2012, 21:09 »
Thought i recognised that golf in your sig mike. I'm the bloke who brought the bonnet of your dad the wk end.
Offline mikemk4gti
« Reply #13 on: 01 May 2012, 21:17 »
It was running fine back then, only packed up today :(
Offline mk2bal
« Reply #14 on: 01 May 2012, 22:19 »
Not witnessed it myself, but have heard of it a few times now. It seems having the gearbox earth removed causes starter return currents to flow through the ecu killing it. Always ensure all earths are in place before connecting battery/ new ecu. Also I think you want to connect earth before pos, as you ensure a return path which some components require
Offline mikemk4gti
« Reply #15 on: 02 May 2012, 15:40 »
Ordered a replacement ecu now, hopefully it will be here tomorrow.
I've fitted a new earth from the battery to the gearbox. Is there anything else I should do or check to prevent it happening again?
Offline clipperjay
« Reply #16 on: 02 May 2012, 16:06 »
Do you have a braided one from the ECU to the bonnet?
Plus we tend to double the negative lead to a gearbox bolt.
Offline tomp
« Reply #17 on: 02 May 2012, 18:36 »
I'm sure its positive first when reconnecting a battery, and positive last when disconnecting....
Offline mikemk4gti
« Reply #18 on: 03 May 2012, 12:25 »
It's fixed, the replacement ecu turned up this morning.
Offline mikemk4gti
« Reply #19 on: 03 May 2012, 12:27 »
No there's no earth on the ecu at all? Should there be?
I added another to the coil as I had a spare from another mk2 I'm breaking.
