Author Topic: hiding the areal  (Read 3190 times)
Offline stainesy
hiding the areal
« on: 29 April 2012, 22:38 »
ok on my new early mk3 gti the areal is on the wing. im planning on getting rid of it as it looks nasty.
i will be filling the hole in and doing some kind of hidden areal inside the wing.
what do i use as the areal inside the? and will i be able to get the radio ok like that?
Offline Deano2711
  • 1992 VR6
Re: hiding the areal
« Reply #1 on: 30 April 2012, 00:01 »
Mine runs along the inner wing from the scuttle panel area towards the headlight. Cannot be seen at all and reception is good. I have no idea why mine is there as I have the roof aerial on mine but I cannot be bothered to change it.
Offline stainesy
« Reply #2 on: 30 April 2012, 07:15 »
Is yours the actual areal that would normaly be on the wing or some bit of wire?
Offline tshirt2k
  • Been there...Done that...
« Reply #3 on: 30 April 2012, 08:23 »
Can you not get one of those aerials that work of the heated rear window? wondered what an areal was at first. :smiley:
Mk3 ABF 16VT Megasquirt V3
Offline stainesy
« Reply #4 on: 30 April 2012, 08:57 »
Aerial then  :grin:
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 30 April 2012, 18:59 »
Wing mounted aerial that has been put inside the engine bay Bud  :cool:
Offline stainesy
« Reply #6 on: 30 April 2012, 20:32 »
sweet think that is going to be what i do then.
just won this on ebay to blank the hole in the wing  :cool:
http://www.ebay.co.uk/itm/350559733669?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1680wt_1037
« Reply #7 on: 30 April 2012, 21:05 »
I used an interior aerial on mine, it bonded to the front screen in the top corner.
Offline Deano2711
  • 1992 VR6
« Reply #8 on: 30 April 2012, 21:09 »
You already have the aerial it's just a case of moving it inside the bay and using the grommit you've already won to fill the hole left. Easy job really if the weather improves enough to do it  :wink:
Offline stainesy
« Reply #9 on: 30 April 2012, 21:38 »
Yeah that was my plan.
Gona spent tomorrow going over the car doing all the little bits and bobs that need doing.
