Author Topic: Induction Kit Heat Shield & VCDS Log  (Read 2950 times)
Offline Scott D
« on: 28 April 2012, 20:55 »
I have been trying a few different intake setups recently being a standard smoothed airbox, enclosed induction kit and a Jetex cone with 3" air feed from the lower front grill.
I can't find all the logs but do remember the Jetex performing best with a peak g/s of 186 and the worst being the enclosed kit which is a shame because it had the least amount of turbo lag and felt awesome low end but was seeing lowest peak MAF readings.
Found a seller on ebay who makes heat shields for the S3 which do fit the MK4 and for £30 worth a try. Have covered the shield with heat reflective tape as well which by all means is not exactly pretty to look at but functional - did a few runs today and afterwards the cone still felt cold where as without the shield it would be warm.
RUN 1 - 2nd Gear
(G28)   (G70)   BHP
/min    g/s   (EST)
3680   152.81   191.01
4240   161.72   202.15
4600   171.61   214.51
5040   179.83   224.79
5400   183.81   229.76
5720   185.5   231.88
6040   185.19   231.49
6320   189.5   236.88
6640   190.53   238.16
6880   186.94   233.68
7120   186.22   232.78
7280   180.89   226.11
RUN 2 - 3rd Gear
(G28)   (G70)   BHP
/min    g/s   (EST)
3560   146.56   183.20
3800   149.47   186.84
4000   149.11   186.39
4200   156.44   195.55
4440   169.44   211.80
4600   172.94   216.18
4880   178.67   223.34
5000   180.08   225.10
5160   182.17   227.71
5360   182.08   227.60
5480   184.36   230.45
5640   183.36   229.20
5800   184.64   230.80
5960   184.64   230.80
6120   188.39   235.49
6200   189.83   237.29
6160   192.42   240.53
Unfortunately had to cut the 3rd gear run short as was running out of track but very very happy with the results - highest peak reading from the MAF I have seen on this car and using the x1.25 calculations 240.5 bhp at 6160 is quite impressive for a K03s.
I'll be getting it on a dyno soon but going off the logs seems like £30 well spent  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline JimBR
Re: Induction Kit Heat Shield & VCDS Log
« Reply #1 on: 28 April 2012, 21:46 »
Exact same shield i've got (and filter I think)  :smiley:
Is that the JETEX filter with the 70/80mm neck?
Glad to see it makes good power  :smiley:
« Last Edit: 28 April 2012, 21:48 by JimBR »
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 28 April 2012, 22:01 »
nice bit of DIY there!
Offline stfc_gti
« Reply #3 on: 28 April 2012, 22:17 »
Gonna give this set up a go. Gonna use a pipercross foam filter though. Will it still be ok?
2002 1.8T GTI AUM, Standard (not for much longer)
« Reply #4 on: 29 April 2012, 00:16 »
Yes but will be bonkers loud, I know as I tried one.
Offline Scott D
« Reply #5 on: 29 April 2012, 20:35 »
80mm neck it is
easiest diy ever it was  :grin:
Offline JimBR
« Reply #6 on: 29 April 2012, 21:45 »
Exact same setup I've got  :smiley:
I bought the 80mm one just incase I ever decide to go K04  :grin:
