Golf mk4
Wazzzer
R32 bumper / arch liner
Topic: R32 bumper / arch liner (Read 1700 times)
jockgti
Guest
28 April 2012, 20:46 »
hi,if you swap your normal front bumper for an R32 one do the arch liners still fit ok ? or is something else needed? and also does the cupra splitter bond or is it clipped on somehow? cheers
Last Edit: 28 April 2012, 22:05 by richw911
Stuart_tate41
Re: R32
28 April 2012, 20:58 »
You'll need to extend the arch liner, you can just screw the LCR splitter on the bottom of the bumper
jockgti
Guest
Re: R32
28 April 2012, 21:32 »
extend it how? by adding something to it or ?
Stuart_tate41
Re: R32
28 April 2012, 21:48 »
I seem to remember that the .:R Line bumpers came with an arch extension when bought new from VW. But I mean if you want to extend it you can probably do a DIY job easy enough I'm sure you could get some arch linnets from a scrap yard and knock something up.
jockgti
Guest
Re: R32
28 April 2012, 21:52 »
right ok that's what i was trying to get at,if there was a proper thing to buy or a diy job cheers
cullygti
Re: R32
28 April 2012, 21:58 »
i made my own arch extensions out of an old black bucket
il take some pics and put them up for you tomorrow jock
as for the splitter i used a small drill bit pre drilled the holes and used small nuts and bolts to fix it this way if you ever want to remove it you can do it easily
jockgti
Guest
Re: R32
Reply #6 on:
28 April 2012, 22:01 »
just found a thread on ukmkiv's with part numbers for extensions from vw will phone them monday see how much
cullygti
Re: R32
Reply #7 on:
28 April 2012, 22:03 »
diy it ...its more fun knowing you built it
jockgti
Guest
Re: R32
Reply #8 on:
28 April 2012, 22:04 »
is there a big gap to cover or is it quite a small distance?
topher
Administrator
Serious forum addict
fully functioning
Re: R32
Reply #9 on:
28 April 2012, 22:05 »
its roughly 25cm long and 4cm wide at the lowest point then tapers up
i think i paid about £6 each for them from the dealer. Then i found a pair of them already in the box along with the replica R32 sideskirts i bought. And after all that i found my arch liners didnt need extending they seemed to line up fine with an oem bumper
Golf mk4
Wazzzer
