Author Topic: Found a leak  (Read 2261 times)
Offline sychosis
Found a leak
« on: 27 April 2012, 08:36 »
Came out to go to work this morning, noticed cd player wire sticking out under glovebox, went to tuck it back and came out with wet hand  :angry:. What usual suspects should I be looking for? Windscreen, pollen filter etc?
Offline javalin
Re: Found a leak
« Reply #1 on: 27 April 2012, 11:32 »
yes
Also worth checking the drains in the scuttle (where the ECU and windscreen wiper motors are)
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline sychosis
Re: Found a leak
« Reply #2 on: 27 April 2012, 11:39 »
yes
James
Check them as in blockages?
Thanks
Offline javalin
Re: Found a leak
« Reply #3 on: 27 April 2012, 11:48 »
yes - otherwise water off the windscreen fills it up....
see - http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/raintray/index.htm
gives you an idea of where I mean.
James
Re: Found a leak
« Reply #4 on: 27 April 2012, 11:54 »
You may also have a leak from the heater matrix.
Offline javalin
Re: Found a leak
« Reply #5 on: 27 April 2012, 11:55 »
yeah - is it water, or water+additive?
Offline Deano2711
  • 1992 VR6
Re: Found a leak
« Reply #6 on: 27 April 2012, 12:03 »
Do you have a sunroof ??
Offline sychosis
Re: Found a leak
« Reply #7 on: 27 April 2012, 12:37 »
No additive, just water
No sunroof
Re: Found a leak
« Reply #8 on: 27 April 2012, 12:39 »
If it is just water I would check your pollen filter plus that the scuttle drains are free.
Offline sychosis
Re: Found a leak
« Reply #9 on: 27 April 2012, 12:56 »
Cheers guys, I'll take a gander later.
